Beeping noise DWF 416
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Beeping noise DWF 416
Viewing 6 posts - 16 through 21 (of 21 total)
  • #203837
    Re: Beeping noise DWF 416
    Filters are in the middle of the base of the cavity, in front of the bottom rotor. Or should be.
    izzer
    My Dishwasher is still full of water when i open the door, i cant get it to empty, Any ideas please?
    #203839
    Izzer,
    Sorry – all the information is there for you. You have a blockage and a leaky circulation pump. If you are unable to solve the problem, you must get some pro help – click the reapirs@ link below for a UKW repairer in your area. Before the Mrs gets fed up with the Marigolds………
    izzer
    Thanks for the info, but i think ill just buy a new one. These machines arent built to last these days.
    #203841
    izzer
    I bought a new washer and when i came to fit it and took out my existing one i found the blockage in the waste pipe so i have fixed it now and took the new one back for a refund.
    The leaking pipe on the recirculation pump i have fixed by carefully cutting off the damaged hose and replacing it with a rubber hose of a thermostat off a car and clamping it on with 2 jubelee clips. It works fine and i have used it a few times with no leaks .
    Thanks again.
    #203842
    I’m going to resist the temptation to say “I told you so”. I am…….. I will……. I can’t……..
    I told you so!
    Glad you got there.
