Hi,anyone know how to access main oven door hinges,(need replaced)they seem to be attached to a bracket on bottom,but loosening 2 screws doesn’t allow hinges to come out, any ideas welcomed. Sorry it is a Montpellier range cooker:rolleyes:
outer hinges can be got at. hinges in the middle then you have to remove the whole oven cavity as far as i can see. seen one but never managed to repair it as it would take hours to do
Had beko which has the same design, absolutely stupid idea! So like Dave, I referred customer to Beko as the kitchen was so small had no room to swing a cat! When they came they pulled it apart when they refitted it was even worse than before door didn’t close properly. After 2 engineers, they wrote it off said they could not do any more, gave the customer back their money!
