Re: Beko 1243s dishwasher is dead
As you say you have tested the switch, fuse and socket then I will assume you have access to a multi-meter?
If so and you are experienced with electrics then try and trace the mains “path” through the machine while the supply is dead. ie checking the filter capacitor and continuity to the main PCB.
However if this sounds too complicated then I’d strongly advise you to find an engineer in your local area as this is something you won’t want to do unless you are experienced with electrics and repairs.
Hope this helps 🙂
