Beko 1614w timer keeps going around
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko 1614w timer keeps going around
  • #27636
    fidder
    Have a problem with the timer. It goes around no matter where you set it and stops at the stop position. Sometimes will drain and not others.
    Could it be the timer or the Pcb board? H..E..L…P!! 😥
    #214954
    comptonappliances
    Re: Beco 1614w timer keeps going around
    like most new timers detected error and aborting programm check motor tacho and ntc both likely suspects before going down timer route
