Re: BEKO 1715s
Thanks eastlmark,
I called engineer who showed up today. The flashing pre wash light signifies a memory error. This turned out to be a 00110 error which meant a drainage problem. Well i had discovered a clean filter so the engineer was perplexed as well.
He turned the machine on by holding down the start/pause button as well as the on/off switch. This cleared the memory and he tried the drainage function which worked fine. All he could suggest was a blockage that cleared through when he tested and reset the machine.
Not sure if this is helpful advice but at least i know how to reset the machine now!
Many thanks
Steve_c
