beko 2 same fault
  • #21585
    delta01
    going tomorow both wont run , pre wash light flashing any idea’s please
    #191765
    Washman
    Re: beko 2 same fault
    Try this reset
    the fix for flashing pre wash led, or flashing start/cancelbutton is
    Turn power button off (not at wall)
    Select 90 degree wash
    Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down – Start light will flash.
    Leave power on.
    Select any Spin position.
    Press Start and Cancel button at same time again for 3 seconds – other buttons may start to flash – if they do, press Start and Cancel button together again for 3 seconds.
    Machine should be re-set ready for use.
    Mike
    #191766
    delta01
    thanks mike will try that and keep you posted
    john
    #191767
    cab
    the procedure mike describes is the method on machines (wma1715s)with electronics manufactured before feb 2004. At the point where you select the spin if you press the start button, if a fault code is stored it will be indicated by the on or off position of the five leds on the right hand side.
    cab
    #191768
    delta01
    thanks guys both machines working one needed a pump the other just re-setting
