beko 5100w
  • #81931
    spencer123
    HI having a problem with this model.it fills when a load is in machine washes for a while then takes in more water but over fills ,on another
    occasion at the start of cycle takes in water and over fills from the start of cycle.
    #418187
    Re: beko 5100w
    Check the air pressure chamber and hose to the pressure switch.
    #418188
    spencer123
    Re: beko 5100w
    HI martin,i checked hose seems ok no pin holes,the inlet where hose goes into drum seems clear,when you say check pressure chamber what do you check for and how,thanks
    #418189
    spencer123
    Re: beko 5100w
    HI all still no further on with machine fitted different pressure switch
    still the same takes water in washes for about 10 mins then takes in more water and keeps filling.any ideas would it be a pcb problem.
