Re: Beko 5120 W ocasional rotation, then start /pause light
It doesn’t really matter what the voltage at the heater is. There is absolutely no need whatsoever to live test. A good multimeter or better still a megger is all you need, first to circuit test from the pcb to the heater and secondly to test the heater itself for continuity, resistance and insulation. If the heater fails then you will usually get an error message.
Overfill is either a blockage in the pressure chamber or a tiny hole in the pressure hose.
