Beko 6kg
  • #102687
    davie144
    On a normal wash cycle my washing machine takes in water but then doesnt agitate / spin although on a spin cycle it works fine. Any help / pointers?
    #490042
    andyjawa
    No model number given. Given that it is 6kg it is more than likely a brush motor. And so…if it is a brush motor the carbon brushes is where you start. This is what you are looking for: https://shop.ukwhitegoods.co.uk/beko-carbon-brushes notice how some pictures show very little black carbon brush that is only because you have to bend a metal tang to release the brush – stops them from snapping in transit thats why.
    This little collection are the most common types there are a few others that were used that are not listed here. When / if you go look for them do not soley base things visually but check, as you can, the model fit list to find ya model..
    #490043
    andyjawa
    Any problems come back with the full model number and the serial number and any other numbers as read off the machine`s label not read off the instrument panel – you can post a photo of the label.
    There are a whole host of other things such as no pump out will give you no or poor spin being the most common.You can get tumbles on wash but no spin and that can still be motor brushes until you finally get both not working. Without the model info the possibilities that itself covers a small length book.
