Beko 8kg washing machine WMB81241LW
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko 8kg washing machine WMB81241LW
  • #78421
    peeler40
    The owner pressed pause to add extra rinse to the cycle.
    Now the machine does nothing .Is there a way of reseting the
    8kg machine ,in the same way you reset a 5kg Beko washer ? .
    #405608
    Re: Beko 8kg washing machine WMB81241LW
    Moved to correct forum, why on earth would you post this in Trade Classified. 😕
    #405609
    iadom wrote:Moved to correct forum, why on earth would you post this in Trade Classified. 😕
    Newbie I expect. 😉
    Have you tried pressing and holding in the Start/Pause/Cancel button for over 3 seconds? That should cancel and reset the programme. 😀
    #405610
    Joined 2003, 42 posts in total. 😉
    #405611
    peeler40
    Yes tried holding start/pause to no avail .Another puzzel with the washer ,when you rotate the program dial there is no program display except for just one 40 degree wash proberly the one she was useing when she pressed pause in the first place.
