Beko AB910S woes
  • #63990
    redland_doug
    Hello everyone,
    I have a problem with my Beko AB910S fridge-freezer. Last week we got -E0 flashing where the freezer temp should be. Then it stopped all on its own. But now the freezer temp seems to be too warm. The temperature bar for the freezer varies a lot too – from no bars to 3 bars over a period of minutes. Now, I really don’t think that the temperature in the freezer is really changing that fast, so it must be the stat in the freezer. Does anyone have an idea where it is, where to get a spare and how easy a job is it? I’ve seen other threads stating that -E0 is a temperature sensor failure, so it all ties in. I reckon its feeding duff readings to the main board (which must have seen erratic values leading to the -E0 display).
    My main problems are to understand which of the several sensors this error applies to (I need a part number), and where the dang thing is! I’ve contact Beko for the info, but astoundingly I’ve had no reply!
    Many thanks for any help!
    Doug
    #355743
    Re: Beko AB910S woes
    E0 is the freezer sensor that is reporting an error. Whether it is that or not is open to question obviously but the only freezer sensor that I could find is this one:
    http://shop.ukwhitegoods.co.uk/Refriger … ensor.html
    Where it’s mounted I haven’t a clue, the diagram is not the best and this appears to have been missed on it.
    Also do check the fan motor is okay.
    HTH
    redland_doug
    Beko did get back to me – very helpful too.
    The part I require is the one you mention. Beko confirmed the part number is 4216600385.
    Its located in the rear of the freezer compartment, about halfway up the rear wall. There is a small grill on the left hand side – its just behind there. If you don’t have the ice maker option then its simply a case of taking off the rear panel of the freezer compartment (few screws) and changing it. If you’ve got the ice maker, then its considerably more complex, because all that has to come out first. Hope this helps anyone else who gets this error.
    PS part is widely available, roughly £10 delivered.
    Cheers,
    Doug
