Re: BEKO AB910W Error 8 desperate help please
When you say 8 appears where does it appear, does the appliance work otherwise or what is the problem you have. For instance have you taken temperature readings in the fridge & freezer departments?
No matter how rural you are you should get someone to quote to repair it, if its under warranty Beko should come to repair it within a reasonable time, if its out of warranty its up to you to get someone to repair it.
E8 is an Ice sensor failure by the way. Fans in freezer not running or going slow are the commonest problems with these appliances.
