Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Beko AB910W troubleshooting
- This topic has 12 replies, 4 voices, and was last updated 12 years, 4 months ago by
Malicia.
November 14, 2013 at 9:53 pm #78117
Malicia
Participant3 yr old fridge/freezer unit kept in garage. Both crisper/chiller drawer and the one above in the fridge compartment have started to freeze everything in them. Icecream kept on the top shelf of the freezer beside the ice making tray is turning soft. Any pointers?????
Reading from the test mode are as follows
R -21
F 05
D -24November 15, 2013 at 12:08 am #404511kwatt
KeymasterRe: Beko AB910W troubleshooting
I don’t have access to Beko technical here but if there’s a flap/valve between the fridge and freezer then it’s possible that is stuck open. It’s the logical place to start looking IMO.
That would mean that there is too much cold air being drawn from the freezer so, it doesn’t cool correctly but given cold air falls, would likely mean that lower levels of the fridge started to cool too much. Which fits with the symptoms.
If I remember or, someone reminds me after 9am tomorrow when I’m back in the office, I’ll have a look at the configuration and technical to confirm.
November 15, 2013 at 8:41 am #404512Seamy
ParticipantRe: Beko AB910W troubleshooting
Fan on freezer side is slowed of stopped altogether. Needs replacing, this normally corrects the fault described. No/poor circulation of air, cold air will collect at bottom as described in post above.
November 15, 2013 at 9:13 am #404513kwatt
Ah, that’s be this fan motor…
http://shop.ukwhitegoods.co.uk/43058913 … -fan-motor
Fairly common to be used as it fits a number of models.
November 15, 2013 at 1:11 pm #404514Malicia
Thanks Guys,
Part ordered. Is this an easy swap over?
November 15, 2013 at 3:44 pm #404515SAMURI
Yes easy to replace on this model when you take the top back panel off inside the freezer.
The fan is only held on with 2 screws and it plugs in so no wiring to do.
Bob
November 15, 2013 at 7:25 pm #404516Malicia
Hi Bob, Is it the panel behind the ice trays? Does it just pull off?
Thanks,
FionaNovember 15, 2013 at 10:13 pm #404517SAMURI
Yes it is behind the ice trays and it just clips in so you just have to pull it off.
It is best to pull it near the top centre you need to put a large screwdriver or large Allen key in the vent to pull it.
But be careful not to damage the polystyrene insulation under the cover.
Bob
November 16, 2013 at 3:39 pm #404518Seamy
Biggest problem i’ve had doing them is the screws break when trying to remove them, must be made of pewter, lots of the heads have come off on me.
November 19, 2013 at 9:42 pm #404519Malicia
Once replaced, should the fan start up once the fridge/freezer is switched back on or how does it operate?
November 19, 2013 at 11:35 pm #404520SAMURI
Sometimes you have to wait until the temperature drops before the fan starts
BobNovember 20, 2013 at 6:38 pm #404521Malicia
Can anyone tell me what readings I should get in test mode if everything is working ok after replacing the fan?
ThanksNovember 21, 2013 at 9:30 am #404522Seamy
Doors switch needs to be made closed for fan to operate I think.
Temperature readings shoud return to normal if all is working o.k. -
