Beko American fridge leak
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Beko American fridge leak
Viewing 15 posts - 1 through 15 (of 15 total)
  • #102272
    marc.knuckle
    Hi all. First time posting, hopefully i can get help with my fridge.
    As well as the constant leaky water dispenser we wish we never chose, and they’ve replaced 3 times now, we’ve had pools of water underneath twice now.
    The first time i googled a bit and found i should take off the vent at the rear bottom and check the white pipe for blockage. It was in fact blocked with slime, the little trap door couldn’t open. I never got to the bottom of where it was actually coming from as i only found one hole inside that looked like a drainage and it seemed in a different place to where the white pipe was and when i took a photo of it using my phone inside the fridge it looked like it was not a hole at it seemed like a grey plug of some sort. Anyway i cleaned away the slime from the white pipe behind and a bit of water came out.
    Few months later and we noticed water around the bottom again. Checked that rear pipe and not blocked this time but when i took it off completely and put a pipe cleaner around in there, some small amount of slime came out and then about quarter cup of water. I checked that inside hole again and it had water level with the top that wasn’t going anywhere and the very bottom of the fridge had a big pool.
    So all in all i guess drainage is the issue but i don’t know what i can do next to find any blockage and prevent it happening in future too. I don’t even know if that inside hole is anything to do with it but it makes sense it is.
    Any help appreciated. I have a photo of the pipe at the back and the hole i was looking at inside but i don’t know how to post them on here.
    Model is – g91635ne, product number 7290346385, serial – 21-101287-10
    #488161
    marc.knuckle
    Any help with this guys?
    #488162
    marc.knuckle
    Not sure the value of this forum when there’s no response from anyone including moderators. It seems all the latest posts are lacking any support.
    #488163
    don
    There are various reason why no one has replied.
    It could be that there are no engineers on here who are familiar with the product or indeed the fault. Not everyone visits the forums regularly as they are out on calls earning a living which comes first. As moderators even we don’t know the answers to all the models and issues.
    Oh and lastly none of us get paid for helping out on these forums, we do it because we like to help the public.
    [USER=”4209″]electrofix[/USER] can you help the OP?
    Don
    #488164
    marc.knuckle
    Thanks, i realise you don’t get paid and i appreciate the response. Simply seeing all the latest threads with little or no replies made me think the forum was abandoned. Hopefully i may get further forward now thanks.
    #488165
    unfortunately frides is not my area of expertise
    there must be a valve of sorts and this is leaking
    have looked at the tech but it does not show me clearly how it works
    it does show me ho it comes off and will post that below
    marc.knuckle
    No we haven’t had any water in the dispenser for a while and it’s not hooked up to the mains so it’s nothing to do with that part.
    I only mentioned this at the top as that bit I’ve given up with and stopped using.
    It’s to do with the white pipe at the rear and/or the inside hole.
    As mentioned i have photos bit don’t know how to post on here.
    #488167
    when i try to clear blocked drain holes I use a long cable tie
    its soft and plastic so it does not damage the tube
    dave
    #488168
    marc.knuckle
    It’s at if there is a rubber plug in there when checking from the top but it’s not aligned with what I’m seeing from behind so it might not even be the drain but i can’t see any other holes from the inside.
    How do i post a picture and I’ll put it on here?
    #488169
    as clong as its under 2M size just upload and post
    if its bigger host somewhere else and post a public link
    marc.knuckle
    The white pipe is what i cleaned a bit and water came out and the grey hole is on the inside but not inline with the pipe
    #488171
    as i dont know these units the drain holes are situated below where water will form
    that hole looks blocked is it ice if yes try a few grains of salt to melt it
    marc.knuckle
    No it actually only felt like rubber when i squished my finger on there.
    #488173
    where is this hole ? as i cant see from photo
    #488174
    marc.knuckle
    It’s inside. Behind the second up from the bottom tray.
