Beko AP930S Fridge Freezer
  • #98692
    Hollytree_Technical
    Hi all
    can anyone provide me with the technical info for this unit please?
    IND: 7219346382
    Serial: 0810005901
    Thank you
    Jem
    #473415
    sorted
    check your email
    Hollytree_Technical
    Well I went back last night and fitted some new bits to the ice maker and a new solenoid for the dispenser flap in the door and then discovered a couple more issues/problems.
    1: It seems to be activating the primary water valve once a second constantly (it doesn’t activate either the ice or secondary water valve till I ask it to), I am assuming that this is not meant to happen and that it will be the main board at fault?
    2: If I select either of the ice modes on the display then it activates the flap solenoid even if I am not asking for ice (it doesn’t activate the auger till I press the lever), again I suspect a main board fault.
    Can anyone confirm or deny my suspicions above?
    Thank you
    Jem
