Cannot get any water in ice cube tray – valves all measure ok on megger – water dispenser works o.k but no water to ice tray – pcb was changed a couple of months ago by another company. Does anyone have any ideas what could cause this fault . Franz
you have one main inlet valve and 2 others 1 for ice maker 1 for water, if the dispenser is working then the main valve and dispenser valve must be ok, just one left to check, it might be ok on the coil but is the valve opening ?.
