I called to a customer with an E8 error on his Beko AP930X. The Ice maker tray sensor was o/c (common fault) so I replaced the Sensor after already attempting to repair it.
He has called me today to say that there is no ice and that it now flashes “F9”.
Without access to the fault code from the machine board cover I am a bit mystified.
E9 (Ice machine failure):
– Entry: If switch does not change as described during initialisation or, while rotating ice machine, if SW position does not change in 1 minute
– Behaviour during error: Ice machine should not operate.
– Exit: If ice-off is selected, or if during initialisation switch changes as described.
