BEKO ASL141S – Water In Bottom of Fridge
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum BEKO ASL141S – Water In Bottom of Fridge
  • #100032
    LukeRidgwell
    I have an issue with water collecting at the bottom of the fridge side of this fridge freezer. Temperature/operation of both fridge/freezer seems fine and no issues with water/ice build up in the freezer.
    Having searched this issue most sites advise cleaning the drainage hole but this particular model does not seem to have a drainage hole.
    Any advice on potential easy-fixes that could be investigated before calling someone in would be appreciated.
    Thank you 🙂
    #478977
    there is no metion in the owners manual but there has to be a way for any condensation to get out so there will be a drain there somewhere
    LukeRidgwell
    I have looked and looked for a drain hole but there is nothing obvious anywhere at the base of the fridge…
    #478979
    there has to be one somewhere or a way of removing wet air into the freezer for disposal
    looked at tech manual and it does not show how its done plus i have never seen one
