Beko ASP341x leaking water
  • #100984
    Tom
    Hoping someone is familiar with this model!
    I have been keeping away from American Fridge Freezers but have been assked by a regular customer to have a look.
    Beko model ASP341x leaking water from the fridge side.
    water is gathering under the bottom drawer of the fridge until it overflows out the front on to the floor. After drying it all up it gathers again within a day or so.
    I havent dismantled anything yet. There is a water container with pipes attached behind the bottom drawer but i am satisfied there is no water escaping here. I suspect the water may be dripping from further up behind the panel in front of the rear wall of the fridge. Is there a drain (as in an simple auto-defrost fridge) that is supposed to be taking this water away for evaporation out the back of the unit.
    Any help or advice will be welcome. Thank you in advance.
    Tom
    #482915
    there has to be a drain for fridge condensation
    Tom
    Thank you Dave.
    My question should have asked “If there is a drain where exactly is it located”?
    I didnt spot a drain hole and wasn’t sure if american fridge freezer system of cold air cooling was supposed to cause condensation in the fridge compartment. Excuse my lack of knowledge.
    #482917
    you could be right as my knowledge on these is limited as I don’t work on them either
    have you checked door seals as if excess damp air is getting in it may overload system
    have got service manual but cant see anything that may help but your welcome to it if you need it
    Tom
    Thanks again Dave, for your reply. I’ll investigate further. May come back for the manual.
    Tom
