Beko B5T4923IW (7188235980) door hinge swap.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko B5T4923IW (7188235980) door hinge swap.
  • #102129
    hebegebe
    There must be a simple answer to this one and I hope someone is able to help me to figure it out, I went to this dryer this afternoon to simple change to door from left hand opening to right hand. I can’t get the door glass out. I’ve watched a YouTube video which makes it look so easy, but I simply can’t get the door ‘glass’ out to turn it around. Does anyone know the secret? I’m hoping to go back tomorrow for a second attempt. Your help would be very much appreciated.
    Graham
    #487656
    Hi Graham
    check your email sent you the manual
    hebegebe
    Thanks for the manual Dave. I regret that on this occasion the dryer won and I had to retire defeated. It appeared to defy rubber work gloves and brute force.
    It appears that every incarnation of this machine has a different method of fixing the door glass.
    If anyone should find a way of doing it, I would be interested to know the solution.
    Graham
