I have a problem with my Beko b5w5941aw Wash machine. Bought it from fbk market and the guy blocked after me as he sold it broken. So the issue : drum don’t spin. Things I have checked : motor disconnected from wires checked with multimeter returns values of 7-10 ohms between pins 1-2, 1-3, 2-3. Water intake works fine. Drain works fine.
Removed the computer bord checked against burns and melted plastic visually looks ok. Motor board assembly look ok visually and also the power card.
When programme is selected like any of them it locks the door , start water intake but when the drum is about to spin there is a light inside which is flashing probably highlighting that is a issue (normally i understand that light should be on all the time). Now I turned on and off in few instances and at some point (i was in the drain+spin mode) the motor spined but when i stop and changed the programme it didn’t spin anymore. Did anyway come across similar problems with similar models or same ?
