Model WM6152W
Complaint of very short motor action then machine cut out. It was firing up to full speed instantly.
I went to this machine a couple of weeks ago, checked the motor, wiring, motor plug, tacho, tacho magnet, continuity from motor plug to PCB. All absolutely perfect, machine lightly used, brushes fine, insulation readings on motor good.
I replaced the PCB and it has worked perfectly for 10 days but is now doing exactly the same thing again. 😥
I have plugged in a new motor to test which also goes right into spin speed.
I have examined every inch of the wiring harness and can find no faults.
What have I missed, its not going to be worth changing both the PCB and motor.
