BEKO BC73F OVER FREEZING
  • #88493
    SteveFitz
    Can anyone advise me on this fridge freezer that is over freezing in fridge compartment i have replaced the small PCB Thermostat in the lamp holder and it did seem to maintain temperature over the a long weekend however it has started over freezing gain, lots of advice on here about foamed in sensors but nothing specific to this model? can’t see any suppliers offering other sensors for this model so I’m thinking its a main PCB issue or the foamed in sensor. There’s plenty of advice about a mod for the likes CDA539/543 that runs in the region of £9 but again no mention of this model.
    Any ideas?
    #438336
    Re: BEKO BC73F OVER FREEZING
    not a lot of tech info on this one seems to be on the change from normal to electronic stats
    have sent you the sensor change info there are only 2 sensors and neither are foamed in
    there are also 3 models
    BEKO BC73 F 7231846319
    BC73F 7244746318
    BC73FC 7516520002
    SteveFitz
    Thank Dave much appreciated
    I have received the sensor change info thanks, I had seen this before wasn’t convinced it applied to this model though as i couldn’t find anything to back it up?
    I need to drag this thing out has there are no other identity/serial marks on front of appliance.
    Thanks again
    Steve
