My beko dishwasher is filling with water then it’s trying to pump it around the unit, making a “try and die” noise, only a tiny bit of water comes out of sprayers. It does that for few minutes then drains water away and switches itself off.
I stripped it and found no blockages anywhere. There are two possible reasons for this happening that I can see.
1. The heat/recirculating pump failed – rotor feels fine when spinned by hand
2. The valve failed and pump is trying to pump against closed valve and stops – this looks more likely
Anyone had that issue before?
What would you say it is? Thanks
