Beko BDVC667w Problem with hob
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko BDVC667w Problem with hob
  • #83852
    ray.t
    Been to have a look at this oven, customer says 3 of the 4 rings heat up to whatever temperature you set them at and then switch off but don’t come back on again. If you then turn them off they will come back on again.
    Just trying to get some pointers to see if its going to be the ring or the switch at fault.
    Cheers,
    Ray
    #423970
    Chris Blatch
    Re: Beko BDVC667w Problem with hob
    There can be a PTC fitted to the rear oven wall that can cause issues with 3 out of 4 hob rings.
    #423971
    ray.t
    Thanks Chris, you don’t have a part number by any chance do you? Just looking through the list of spares on connect and it brings up no ptc
    Cheers,
    Ray
    #423972
    Chris Blatch
    Hi again Ray,
    Looking at the manual, none are shown as fitted. I remember finding a PTC in line with the live feed from the terminal block on a few models, it would only supply 3 of the hobs, bizarrely. In can’t remember the models though.
    However, following the schematic, the hobs are fed as 2 separate circuits: Hobs 1 and 2 are fed from L1 terminal block and 3/4 from L2,
    I would have a look at the terminal block itself, they use a polyphase type with links in, check there are making contact etc.
    #423973
    ray.t
    Hi Chris,
    Thanks again for your help I will check it out.
    Cheers,
    Ray
