Hi.. I am fitting a new kitchen and will be installing a ceramic hob.
The oven I will be fitting is a beko be62fs and is 2.2kw
can I run this from an ordinary 13 amp plug? or will it need its own large cooker type supply?
the reason I ask is that I assume my new hob will need a big power supply,( the cooker supply) so will I need to get another fitted to run the oven. or can I use an already avaliable 13amp socket?
