Hi all,
I can’t see the answer to my problem by searching so here goes….
Basically, the freezer on my Beko fridge / freezer isn’t working properly; it’s too warm (0 degrees – should be -15 to -20?). The fridge doesn’t feel very cold either.
The unit is an upright one with ‘exposed’ elements in the freezer part (i.e., the elements make up the shelves in the freezer). There are no warning lights or anything like that on this model.
I’ve noticed the following things:
– the unit is making the normal ‘noise’ of the compressor humming
– the unit is almost constantly making a sort of gurgling noise, as if lots of water is being pumped around. This started when the problem started
– it doesn’t matter which setting I use on the dial – the fridge never clicks off
– the compressor is very hot; it feels as hot as a radiator to the touch
Having read other posts on Beko fridge / freezers, I’m pretty much prepared for having to replace it, but if someone can come up with a fairly inexpensive check I can carry out before splashing out a few hundred quid on a new unit, I’d be most grateful.
Jerryg
