The fridge department of my Beko CA5411FFW/2 Frost Free Fridge Freezer has now become so cold that any liquids therein have frozen solid, even with the thermostat control on its lowest setting.
Not sure where to start, so any useful suggestions as to how I can resolve this problem would be gratefully received.
Re: Beko CA5411FFW/2 Frost Free Fridge Freezer-Fridge is Fro
There is a sensor buried in the back on the fridge evaporator which is most likely the fault you have. Cheap enough but a pain to dig it out from a diy point of view (means cutting into the insulation at the back) easier to get someone in to do it £60/£70 tops. Job done.
see post lower down in same forum, Item costs £8.80 inc post from this site,
takes about a hr to do. just done mine yesterday and all is now fine. took plenty of photos, seems a common problem-mine was just 3 yrs old.
regards
john
Hi. I have a BEKO CDA556FW with what appears to be the same problem. I would be very grateful if either of you could let me have the step by step video.
Hi. We also have a BEKO CDA556FW with the freezing Fridge problem. I would be very grateful if someone could let me have the step by step video to enable us to sort it out.
Regards. Willi1ka
