beko ca7015ffs fridge freezer cooling problems ihelp please
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum beko ca7015ffs fridge freezer cooling problems ihelp please
  • #85099
    cowbridge lurcher
    helppppppppp please started about 4 days ago heard a buzzing sound in kitchen opened freezer door and food was just starting to defrost rushed this into our other freezer . anyway checked it for an ice build up none , switched the unit off and waited about an hr then turned it back on it started ok the fan blasting chilled cold air into the freezer ice cubes froze but then the fan stops and starts [ this is the buzzing sound fan kicks in and stop starts ] replaced the pcb board in fridge compartment but did not solve the problem any help would be fantastic thanks paul
    #427724
    cowbridge lurcher
    Re: beko ca7015ffs fridge freezer cooling problems ihelp pl
    BUZZING COULD BE COMING FROM THE COMPRESSOR ANY IDEAS PLEASE
    #427725
    cowbridge lurcher
    WELL THANKS FOR THE NO REPLYS ! i managed to fix it after replacing the small pcb board in fridge then bi metal thermostat in freezer and finally the main pcb board fridge freezer is blasting out cold air at last
