Beko – carbon brush uneven wear?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko – carbon brush uneven wear?
  • #75756
    neilsukwg
    Model WMA767W with digital display
    Customer reported a funny noise (brushes) then machine stops
    I remove brushes 1 is shiny with about third left the other is worn down completely burnt etc with no sign of arcing or anything sinister
    Replace brushes but machine will not program
    Display is lit and changes to the correct setting when you turn dial –
    Door does not lock (tried new interlock)
    will not start
    Can’t find any info on reset procedures
    On hot washes a small indicator in bottom of display shows F3
    Neil
    #396037
    neilsukwg
    Re: Beko – carbon brush uneven wear?
    Just after some ideas – had to bump because customer on phone 3 times since last night :rolls:
    #396038
    A1engineer
    Does sound like a motor fault, check the wiring around the motor 1st 🙂
    #396039
    keithwilliams
    i had one couple of weeks ago. the carbons were in green holders. it did look like one was worn right down but in fact had got stuck. it took a bit more than usual effort to push it out.
