Thanks for reply. Not the brushes fitted to this machine. Motor is made by schunk. Carbons have white back plate. I think this may be part no. G613803as. I’ve never come across them before.
Happened to me before when looking up the brushes for a Beko machine, it comes up with something but in real life they’re not what is fitted.
If you have an ASWO account you can get them from there.
Was confused to start with as also had not come across them before. Took me a while to find them, in the end, I used their Product Finder with dimensions and there they were.
For this model
Early motor 2826520100 uses brush 371202407 (Connection tag faces down)
Late motor 2838520100 uses an unlisted brush (Connection tag faces up) which is available from ASWO – Pattern P/N #G613803.
Other models also have early and late motor versions optionally using the #G613803 type brush.
Have kept this brush in stock for quite a while now
