BEKO CD4543FW f/Freezer not cooling
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum BEKO CD4543FW f/Freezer not cooling
  • #57964
    yam-wr400f
    This is driving me mad!
    fan in freezer running no problems, changed thermostat, still compressor running (normal temp) but both fridge and freezer not cooling?
    There is a gurgling sound from the pipework??
    Have cleaned the fins on the back of the appliance.
    Does it need re-gassing? Is this something I can do at home?
    Is there a kit needed for filling the gas?
    #332819
    MKR
    If its running and not freezing, then you have a gas problem… the gurgling usually means it’s a gas leak.
    Look for oil traces from the leak on any pipe-work… and look for rust on condenser at back where it touches insulated pipes.
    If you find a leak, call an engineer.
    #332820
    Re: BEKO CD4543FW f/Freezer not cooling
    yam-wr400f wrote: Is this something I can do at home?
    Absolutely not, unless you intend to lay out several £1000’s and invest in highly specialised training. 😉
