Beko cda 565 fs
  • #82296
    wilc
    Hello having problems with the above model have changed all the parts main board temp probe thermostat etc. its not regulating the temperature in the freezer/fridge gets to about minus 9/10 switch’s off takes along time to come back on +6 in freezer can I frig it out any way to make it run on a timer thanks Wil compressor sounds normal
    #419439
    wilc
    Re: Beko cda 565 fs
    Hello still no answers to my post shall I just bin it or is it worth fixing Wilc only 1 part I havnt replaced is the sensor that goes into the block connector top right that’s cable tied onto freezer pipework ❓
    #419440
    SAMURI
    Re: Beko cda 565 fs
    The model you have does not have a thermostat but is controlled by a PCB and a small control PCB plus sensors.
    If you have replaced the main PCB at the back and the small control PCB and the compressor is not running all the time and cuts out as it should but not reaching temperature.
    The most likely fault will be the fridge sensor this is foamed in.
    If the compressor is hot and runs all the time then it is a gas or compressor fault if it not reaching temperature.
    Bob
