Beko CDA539FW/2 – Fridge is freezing
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Beko CDA539FW/2 – Fridge is freezing
  • #91247
    Gav_989
    The fridge section of my Beko fridge-freezer (CDA539FW/2) has began to freeze, to the extent that I can’t use it unless I want to use it as a freezer.
    I noticed there was a previous thread which was similar but for the model CDA539FW/1. I assume there is maybe be a different solution being s different model?
    Can anyone help?
    Thanks,
    Gavin
    #447543
    jskelton555
    Re: Beko CDA539FW/2 – Fridge is freezing
    most common problem with these are sensor failure, this is located in the insulation at back of fridge area. access is only by cutting away insulation. sensor is £11 if memory serves me right. check out video on youtube, beko sensor repair
    regards
