Beko CDA539FW-2 Thermistor Values
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko CDA539FW-2 Thermistor Values
  • #84002
    Hollytree_Technical
    Hi all
    Does anyone know the nominal values for the thermistors in this unit please as I have been to see a unit which is running both fridge and freezer too cold (-5C and -37C), I am getting readings from both NTCs and can’t find any fault on the PCB and no Insulation Resistance problems.
    If no one knows then I may just get a board and fit it anyway as they are cheap.
    Jem
    #424474
    Re: Beko CDA539FW-2 Thermistor Values
    typical Beko
    the parts list says it a pcb design so does circuits but tech spec says its a ranco stat
    so cant help
    Hollytree_Technical
    I got caught out with this one originally because the print on the label has been done so badly that it was impossible to tell that it was a -2 variant so went armed with the listed thermostat and then got a surprise when I tried to change it.
    Jem
