Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › BEKO CDA539FW frozen fridge compartment
- This topic has 21 replies, 8 voices, and was last updated 12 years, 10 months ago by
wg100.
June 11, 2013 at 7:08 pm #75814
wg100
ParticipantHello,
We’ve got a just under 2 year old BEKO CDA539FW which yesterday has started to freeze the contents of the fridge compartment solid.
From reading the information available on here I’d suspect that it is the thermostat which has failed. Can anyone describe where exactly I should be looking in the fridge for it? I’ve looked in the freezer compartment behind the removable panel, but didn’t see anything which looked like the thermostats described in various info posts on here.
Also, can anyone tell me what thermostat I need to replace it with?Many Thanks in advance.
WG
June 11, 2013 at 9:20 pm #396221Dave_Conway
ParticipantRe: BEKO CDA539FW frozen fridge compartment
The thermostat is part number 4305510500 here:
http://shop.ukwhitegoods.co.uk/43055105 … thermostat
It should be inside the fridge normally 🙂
June 11, 2013 at 9:53 pm #396222wg100
Hi Dave,
Thanks for the reply. I can’t see anything which looks like a thermostat in the fridge compartment, nor in the freezer compartment! I’m slightly confused here!
June 11, 2013 at 10:32 pm #396223kwatt
KeymasterRe: BEKO CDA539FW frozen fridge compartment
It should be in a housing behind the control knob in the fridge.
However, before ordering, I’d be sure that was the problem and that it wasn’t something else.
On that note, here’s some reading for you…
http://www.ukwhitegoods.co.uk/help/spar … stats.html
HTH
June 12, 2013 at 9:54 am #396224wg100
Thanks, I’d already read that article.
In the fridge compartment the only thing in the housing with the control knob is a small circuit board and the light.
I cannot see a traditional thermostat with phial anywhere in the fridge or freezer compartments.
I just pulled the fridge out and saw a sticker on the back with the model number CDA539FW-2. Does the -2 change what sort of thermostat this fridge/freezer uses? Could it be an electronic thermistor setup instead?I’m fairly sure that the thermostat is to blame as the fridge runs constantly, which probably explains the freezing of the fridge compartment. I’ve checked the control knob and the resistance changes as the knob is turned, which makes me think it is working correctly.
I’m hoping that this could be a simple and quick fix!
Thanks for the advice so far.
WG
June 12, 2013 at 10:36 am #396225Dave_Conway
Yep, the -2 version has no thermostat, it is controlled by a PCB here:
http://shop.ukwhitegoods.co.uk/43606201 … rol-module
It’s round the back near the top 😉
June 12, 2013 at 11:00 am #396226wg100
Brilliant. So theoretically this could solve the problem? Is there any way I can check the PCB with a voltmeter to confirm it’s the dodgy part?
WG
June 12, 2013 at 11:17 am #396227kwatt
It will also use a thermistor to detect the temperature which is a more likely explanation than the PCB I would imagine.
June 12, 2013 at 12:30 pm #396228kwatt
I was curious and, got access to the Beko tech site back…
It’s very odd that, they show the board and Dave is totally correct in that it is that one but, it doesn’t show any thermistors at all there. Which is just plain weird.
Then in the tech bumph it says that for over freezing check the fridge lamp is working and correctly in place or, it causes issues. I assume some resistances go outta whack if that’s not right.
The only explanation that I can come up with for no thermistors shown as, after all, it has to detect temperature somehow and it doesn’t use magic, is that it is possibly foamed in like some of the Bosch and Hoover Candy ones are. Meaning that, if it is the thermistor that’s failed, you won’t be able to get it let alone get to it to replace it. 🙁
June 12, 2013 at 12:55 pm #396229Dave_Conway
Foamed in thermistors 😉
I would give the PCB a go though as it’s so cheap, you never know 🙂
June 12, 2013 at 3:45 pm #396230wg100
Have ordered the PCB. It’s coming tomorrow, so hopefully will do the trick. Otherwise I’ll be looking for a new one! Bit annoyed as it’s not even 2 years old, and Beko only do 1 year warranty.
June 12, 2013 at 4:09 pm #396231Dave_Conway
Where did you order it from ?
It wasn’t from us 😉
June 12, 2013 at 4:28 pm #396232wg100
I did phone up, but the part wasn’t in stock, so found another online retailer who had it ready to ship. Needs must I’m afraid!
June 12, 2013 at 9:42 pm #396233Dave_Conway
Actually it is and would have been with you Friday so apologies for inaccurate info :/
June 13, 2013 at 8:25 pm #396234wg100
No worries. PCB arrived this morning and fridge is back up and running. Thanks for the advice.
