Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › BEKO CDA539FW frozen fridge compartment
- This topic has 21 replies, 8 voices, and was last updated 12 years, 10 months ago by
wg100.
September 17, 2013 at 2:51 pm #396235
phowells
ParticipantRe: BEKO CDA539FW frozen fridge compartment
Is the PCB detailed earlier in this forum suitable for Beko model CDA 563?
I have the same issue with the fridge being colder than it should be.
Are they simple to remove and refit?Thanks.
July 1, 2015 at 5:22 am #396236Muba
Hi I have same problem as others fridge getting too cold and ice build up so I’m confused witch part shall I bought pcb or censor.Plz help for giving me parts number both of them.
July 1, 2015 at 9:57 am #396237Muba
hi is anyone can tell me where to locate EVAPORATOR CENSOR on BEKO CDA539FW-2?
THNX
June 17, 2016 at 11:20 am #396238FarNorthOrk
Hi there,
I have an identical problem with the fridge compartment over chilling to the point of icing up.
I’ve checked the control dial and there does not seem to be any ‘click’ as temperature point is changed lower or higher? Is this normal?
I’ve seen posts from folk replacing the PCB with no effect, I was wondering about this small control PCB inside the light fitting section for the thermostat control?
Also, swapping the door hang round to the opposite way has made the door ‘spring’ open due to the door switch being too strong and on the open side of the door, rather than the hinge? Any thoughts on this one? 😕Many thanks,
ChrisJune 17, 2016 at 11:34 am #396239kwatt
KeymasterRe: BEKO CDA539FW frozen fridge compartment
It’s usually not the PCB but the thermistors that are an issue.
It’s electronic so, no clicking.
The two usual suspects are:
https://shop.ukwhitegoods.co.uk/4394720 … air-sensor
http://shop.ukwhitegoods.co.uk/43947201 … dge-sensor
Door I’ve no idea on, I can only think it could be an adjustment of some kind. 😕
November 5, 2017 at 6:25 pm #396240Kerdal
ParticipantRe: BEKO CDA539FW-2 frozen fridge compartment
Hi there
I’m having trouble with a beko fridge.
I have looked at the forum which comes up with very good information.
Usual problem of fridge is freezing up and control knob does nothing and won’t go into defrost mode
I have changed the pcb on the back at the top …but after looking at forum it sounds like a sensor!!!
I have checked location of sensor by fan in freezer,not sure of the other one?
Model is a CDA539fw-2
Serial 1013356611
I understand it is these two items but need to make sure which one goes where..!!
4394720185-electronic-fridge-sensor
4394720285-electronic-fridge-air-sensor
Any help appreciatedDecember 31, 2017 at 12:11 pm #396241Jimbom100
First time using this forum so I hope I do this correctly.
I have the same problem with my Beko CDA 653 FW/1 fridge freezer that the originator of this post had, viz fridge keeps hard freezing.
I have had a look for the thermistor but have yet to find it in the foam insulation. I have dug a hole on the centreline of the fridge and about 100 mm long. Am I digging in the right place? And assuming I eventually find the thermistor, how do I find the replacement part number?
Any advice would be much appreciated.
