Beko CDA539fw too cold
  • #92105
    mapelectrical
    Hi All
    I have a Beko CDA539 that freezes the fridge when the stat is anywhere past the minimum setting.
    Any ideas?
    #450288
    Alanj
    Re: Beko CDA539fw too cold
    Have you tried changing the stat? Usually a small pcb behind stat knob. Not expensive.
    https://connections.connect-distributio … y=cda539fw
    #450289
    smartin
    sorry to jump on your post but I am glad this has been posted, unless you are lucky replacing the potentiometer and pcb at the rear rarely works,most of the time its all to do with a foamed in sensor on fridge evaporator wall which has to be cut out and replaced, my question is, has anybody done one of these ? as there is no info on manusoft other than replacing freezer evap sensor. many thanks
