Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Beko CDA543F Defrost Timer, Have I Tested It Correctly?
- This topic has 4 replies, 2 voices, and was last updated 13 years, 10 months ago by
wokeye.
June 5, 2012 at 1:57 pm #69791
wokeye
ParticipantI found ice in the freezer section of my Befo CDA543F fridge freezer this morning, it was also a bit warmer than normal. I took the cover off to look at the evaporator and it had quite a decent amount of ice built up on it. I found a guide on you tube for checking the 4 connections on it.
http://www.youtube.com/watch?v=tPpLl2d0094
The connectors have no labels on them numbering them 1-4 like the ones he is testing. Basically when the timer is operating normally and not in a defrost cycle it is sending a start signal to the compressor, I am getting continuity between 2 of the contacts. When I rotate the timer dial with a screw driver until I hear a loud click, the continuity is lost when the timer sends a signal to stop supplying a signal to the compressor. But apparently then I should get continuity by moving the multimeter to a different contact as this is a switch being made sending a signal to start the heater and the signal to the compressor is not there anymore. The signal from the 2 contacts to the compressor goes dead at this point but no other 2 contacts are making a switch to send a signal to the defrost heater. I have checked all contacts in all combinations and no 2 pairs make a switch continuity. I have also switched the timer until it makes a loud click and put it back in the machine but the defrost heater does not come on. I just wanted to check that I have done it correctly before I buy another one. I have also read through a search on here that it advisable to replace the defrost heater bimetal thermostat at the same time as it is quite cheap and also fails. Thanks for any advice.
June 5, 2012 at 3:23 pm #375987kwatt
KeymasterRe: Beko CDA543F Defrost Timer, Have I Tested It Correctly?
I thought that this was a new fridge freezer you had?
You will always have use there, some at least, until a defrost cycle runs of course and the heater melts the ice but I don’t know what the various connections are on that one here, no wiring diagram at home.
But yes, they do fail.
The defrost timer should be this one:
http://shop.ukwhitegoods.co.uk/Refriger … Timer.html
And the bi-metal fuse this one:
http://shop.ukwhitegoods.co.uk/Refriger … ostat.html
We usually change both as the timer popping will usually take out the fuse.
HTH
June 5, 2012 at 4:55 pm #375988wokeye
ParticipantRe: Beko CDA543F Defrost Timer, Have I Tested It Correctly?
Thanks for the reply kwatt. Yes it’s new well used off ebay :rolls: It has been fine for several days then I noticed this. Whether it was already faulty when I bought it I have no way of knowing. Thanks for the help and the links, will buy both just hope that this cures it. It should do fingers crossed.
June 5, 2012 at 5:49 pm #375989kwatt
http://www.ukwhitegoods.co.uk/help/buyi … chine.html
The same principals apply. 😉
It probably will cure it but there’s no way to be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure.
Many of the appliances I’ve seen for sale privately on Ebay are, will we say, suspect of having the odd problem.
June 5, 2012 at 9:44 pm #375990wokeye
Cheers kwatt items ordered from links that you posted. I have said it before that I am finished with ebay for any items that can be dubious. I definitely mean it now. Thanks again.
