BEKO CDA543FW – 2007 model (compressor not working)
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum BEKO CDA543FW – 2007 model (compressor not working)
  • #102757
    FrankW
    Ordered a replacement for the CBB65A-2 capacitor (5uF) – (hopefully the faulty part..). The one listed by the eBay seller being a CBB60 (5uF) – the seller replied “I would have thought this type of cap would be for the fan motor rather than the compressor as the compressor is started by the relay on the side of the motor”.
    The Fan works fine but the Compressor doesn’t ‘click-start’ – hence no freezing.
    Is that correct? Is the Compressor (slightly warm when mains-connected) requiring a new Relay instead. The FF has been OK since 2007!
    #490342
    there is a relay on the motor
    https://shop.ukwhitegoods.co.uk/5736330200-fridge-compressor-starting-relay
    if its not that will be a failed compressor
    FrankW
    Much obliged for the pointer (it wasn’t previously suggested the Compressor could be KO’d).
    The linked Relay looks somewhat different but apparently compatible
    So, possibly, time for a new FF..
    #490344
    If you get a click, buzz, no start then the odds are the compressor is fragged.
    To try to put it as simply as possible, the click is the relay trying to start it, can’t start so you get the buzz and all too often the cycle repeats (so you get click, buzz, reset, click, buzz, reset..repeat ad infinitum) as it’s a dumb device in essence so will just keep trying even though it can’t kick in. That click to start will only stop when the pot fires up and runs.
    There are two common fundamental reasons for that the compressor is OC/shorted or, it’s seized internally and either way the only cure is a replacement compressor, a new relay won’t do anything aside 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} confirm the compressor failure.
    FrankW
    That’s very useful info.
    No – absolutely no ‘click’ (or anything) from the Compressor/relay upon switch-on; it just gets slightly warm (stable temperature) with the Freezer-Fan spinning merrily.
    So how would I wire that dissimilar relay?! I’d love to repair this instead of sending it to land-fill heaven…!
    #490346
    That’s just the mains in, the relay is behind that.
    FrankW
    OK – but I don’t understand!
    (no noises as you suggested, anywhere, to indicate the (‘failed’) compressor is trying to operate- presumably implying a still-functioning Relay).
    As the Relay in question appears totally ‘electrical dissimilar’ maybe it’s best to forget any repair.
    Thanks for your time.
