Beko CDA647FW/1 F/F not working
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko CDA647FW/1 F/F not working
  • #52786
    nospin
    Hi, all lights are on and no supply to compressor relay. I have tested the little thermostat switch which has continuity. I have tested the thermal fuse in freezer and ok. All heaters are ok. I have no way of testing the pcb and the top back of fridge other that i tested 240v there. Is this a straight board change please?
    #313120
    A1engineer
    Re: Beko CDA647FW/1 F/F not working
    have you checked defrost timer down bottom white box next to compressor
    #313121
    adv
    yeh give it a turn with end ov screwdriver should come on 😆
    #313122
    BobHope
    Hi nospin,
    two types of appliances with that model no. one has a manual defrost timer located to the left hand side of the compressor these do fail,
    the second is controled by an electronic pcb located on the rear at the top,
    try putting live and nuetral directly onto the compressor and see if it runs, if it does its the timer or pcb if not its the compressor.
    Bob
    #313123
    nospin
    Cheers man, this has a pcb at the top. i will order 1. I left the customer with fridge running anyway. Anyone know a part number please? And where is the best place to buy Beko spares? I seem to come across a lot of them. cheers
    #313124
    nospin
    I have returned and fitted a new board. The machine never fired up. The light inside the fridge is flashing on and off when the fridge door is open. I understand this may be telling me that there is a fault code???
