Beko CDA660FS fridge freezer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko CDA660FS fridge freezer
  • #88210
    dunston
    Beko CDA660FS 7511620010 – this fridge freezer will not start – the fridge interior light switches on. When the f/f is plugged in the freezer fan motor runs for about 10 seconds. We have replace module 4360620185, no change. The fridge freezer is in a very cold garage however the use manual say it can be use in a ambient temperature of -15. Anyone had this fault?
    Mod edit: deleted duplicate post in the general trade forum. Much easier to keep it to one thread in the correct forum.
    #437355
    Re: Beko CDA660FS fridge freezer
    i looked up the board
    got a model CDA660 FS prod code 7511620010
    that shows a board number 4360625185
    not the number you have but both numbers are valid so have you fitted the correct board ?
    dunston
    Yeah, checked number on the module, 4360620185
    #437357
    your module part number ends 0 185
    the part number I looked up ends 5 185
    or are you saying the original board has the 0 185 number on it
    since Qualtex stock both boards there must be a difference prob software
    not much tech info on the can send you the schematic wiring diag if you want but all it shows are 2 ntc sensors
    I would measure the ntc values to see if there is any significant difference
    I know some fridges do a defrost cycle when switched on I take it you left it a while to see if it came on
