Hi, hopefully someone might be able to help. I have a beko fridge freezer, model cda751fs/1, and recently it has started to freeze in the fridge. It is only approx 2.5 years old. There has been 2 types of frost. Originally it was ice so I could heat up a little and would then slide off as a sheet. Now appears to be a bit of frost. I did a defrost over the weekend (off for over 36 hours) and turned it back on and it is still doing the same. The frost / ice is generally on the levels above the drainage hole but some things on the lower door shelf are freezing as well. Any help on this would be greatly appreciated. Also, if spares are required, where could I get them from?
