Hi I have a Beko double oven/cooker with ceramic hob – DC5442W. Everything works fine except the number 2 setting on all the rings !! all the other settings work but number 2 – thought it to be a wiring problem but cant see it !!!
Might be worth a look? check the links on the mains inlet connections?
one might be loose or burnt? IE: L is linked with numbers 1,2 and 3.
Check your instuction book for wiring connections.
power off tho
