Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Beko CFP1691W Fridge/Freezer Malfunction
- This topic has 11 replies, 2 voices, and was last updated 5 years, 8 months ago by
Rawsten.
August 8, 2020 at 4:59 pm #98143
Rawsten
ParticipantFridge section is working OK, but freezer section is staying at roughly the same temperature as the fridge ie. close to 0degC, but no colder. Freezer fan is working. No icing-up anywhere. Door seals OK. So, freezer thermistor or evaporator packed up ? Any informed comments welcome ! Thanks.
August 8, 2020 at 5:15 pm #471048electrofix
Moderatoris the compresssor running all the time or does it start and stop ?
August 8, 2020 at 10:57 pm #471049Rawsten
ParticipantThanks for the quick response, Dave. The compressor runs, then stops, apparently when the fridge temperature has reached its set-point. Fyi (you may already know), for this model there is no separate temperature control knob for the freezer.
Btw, I didn’t mention in my first post that there were a lot of strange wheezing sounds coming from the fridge freezer around the time I noticed the freezer wasn’t as cold as it should be. May be a coincidence though, because yesterday (7th Aug) was hot, even in Manchester.August 8, 2020 at 11:40 pm #471050electrofix
Moderatorwell my take on it so far is the fridge sensor seems to be happy but the freezer one is not
you need to get at the board and measure the resistance of the sensors
one is on a seperate 2 pin plug
the other is on pins 1 and 2 of the other plugthink the freezer one is the second one
if we know a temperature and a resistance we can look up whats correct. As far as i can see they are identical so if they are the same temp it should match. disconnect from board before measuring
August 9, 2020 at 7:19 pm #471051Rawsten
ParticipantThanks Dave. Your help is much appreciated. As you said there are 2 plugs. Looking at the stuffed side of the PCB, there’s a 5 pin plug top right labelled KN2 on the board. To the left, a 2 pin plug labelled KN3.
For the 2 pin plug (grey and orange wires), initial resistance was very close to 20kohm. By the time I had taken other measurements, resistance had dropped to 18.6.kohm. I estimate the fridge temperature had risen by a couple of degrees over that time, to ~5degC. Hopefully those are close to expected values.
The 5 pin plug was a little more complicated. The are 4 wires attached. Fom the RHS: grey / empty / black / brown / red.
The resistance between grey and black was very close to the 2 pin value when measurements were made straight after each other; ie. ~18.5kohm. So, assuming the fridge and the freezer really were at roughly the same temperature – then the freezer sensor appears to be working OK ?
I took resistance readings of all the other wire combinations on the 5 pin plug; the only pair that wasn’t open circuit was red / brown, which gave a reading of 38.6 kohm at the time when the grey/ black measured 18.5 kohm.. Any thoughts on that ?
Btw, I’m still trying to understand how a single compressor and a single temperature controller can control different zones (ie. fridge and freezer) to widely different temperatures. Some cunning valving system ?August 9, 2020 at 9:28 pm #471052electrofix
Moderatorwell that give a temp reading od around 10 to 11 degrees Sound about right ?
the way these units work is the gas goes to the freezer first and only when its not boiled away in the freezer is there enough left to cool the fridge
what i am trying to figure out is why the compressor turns off
sensors seem ok so if its not a compressor fault it may be the boardjust double check compressor is going on and off and at what interval
August 10, 2020 at 6:43 am #471053Rawsten
ParticipantRe. compressor switching: if compressor is off, and I leave the fridge door open to warm it, after 30-60secs, the compressor switches on. Then it runs until the fridge is cooled sufficiently, then switches off. It’s as if the electronics is ignoring, or unaware of, the freezer.
Probably not significant, but even when the fridge and freezer are at room temperature, the compressor has never switched straight on after plugging into the mains. There’s always been a delay of a minute or two.
I’m still puzzled as to how cooling is diverted from the freezer to the fridge ? There must be something that causes the cooling system to switch to the fridge when the freezer has reached its set temperature (of approx -18degC). Maybe the malfunction is in this section ?
Unfortunately, I can’t get back to the unit for a few days now, so won’t be able to make any more tests until then. Still very interested in getting this problem sorted out though.
CheersAugust 10, 2020 at 8:32 am #471054electrofix
Moderatorthe only thing as far as i know, and friges are not my area, is pressure. pressure stops the liquid refigerant expand. If there was a blockage between the freezer and the fridge the pressure would stop the gas expanding in the freezer
if its that its dead
may be one of the fridge boys have an idea
August 10, 2020 at 11:06 pm #471055Rawsten
ParticipantOK, thanks. When I get back to the unit, I’ll take some resistance readings whilst adjusting the temperature control knob, to try to understand where and how temperature control set points for fridge and freezer are fed into the PCB. Maybe the fault is with the freezer set point ? Failing that, I could buy and try another PCB. The consensus seems to be that fridge/freezer PCB’s are pretty reliable though.. Last resort, I could call out a fridge/freezer engineer, and hope it can be fixed at a reasonable price. The unit isn’t yet 2 years old, so I don’t want to give up on it..
One last thing for now: is there a simple equation linking thermistor resistance and temperature, that I could plug into Excel, or perhaps a look-up table available to the public ? You seemed to be using such a reference source earlier in this correspondence. When I looked on-line for this info, there seemed to be a lot of different thermistors in fridge / freezers, with presumably different sensitivities.
Thanks again.August 11, 2020 at 12:14 am #471056electrofix
ModeratorAugust 16, 2020 at 9:50 pm #471057Rawsten
ParticipantSome developments since your (Dave) last post:
– Making a log plot of the data from your table between +10C to -25C gave a close fit to the following linear equation: temperature = ( -18.67 x ln (thermistor resistance)) + 65.24.
– In my absence, the freezer section was reported to be behaving ‘normally’ again. So I took some more thermistor measurements, and used the above equation to calculate the temperatures. I also used an IR temperature gun to get some direct temperature measurements, to cross-check.With the temperature contoller in the fridge set to mid point (setting ‘3’), I got the following results:
– The two pin plug (KN3) gave a resistance of 32.3 kohm, equivalent to a temperature of 0.4degC. The IR gun aimed at the back of the fridge behind the chiller box showed 2-3degC; so, pretty good correlation.
– The five pin plug (KN2), between the red and brown wires, when measured twice at different times (and therefore at different parts of the cooling cycle) gave resistances of 80 kohm ( -16.6degC) and 114 kohm (-23degC).
An IR gun reading taken at the rear of the top freezer shelf was -16degC. So, (a) pretty good correlation again and (b) the freezer section did indeed appear to behaving itself.
You may recall that I previously measured a resistance of ~18.5 kohm between the grey and black wires on the 5-pin plug, and thought that could be the freezer temperature. Well I got almost exactly the same reading again when the freezer was apparently much colder, so the 1st assumption was incorrect.
It transpired that the grey-black wire resistance was coming from the temperature controller: At settings Min, 1, 2, 3, 4, Max , resistances were respectively approx. 50, 40, 30, 20, 10 and 0 kohm. These values must somehow be converted by the PCB into reference values for the fridge and freezer thermistors.So, all making sense now – except I still don’t know what was happening when the freezer wasn’t cooling sufficiently ! As I said at the start of this post, it had been a hot day, and there were some strange wheezing noises coming from the unit. Maybe there was some sort of blockage in the cooling system, as you suggested. Fingers crossed it doesn’t happen again.
Thanks for your assistance.August 16, 2020 at 11:02 pm #471058electrofix
Moderatorhot days can be a problem, lack of ventilation or just struggling to cope with the heat.
adding a small fan can help on really hot days as our fridges are not designed to take high temperatures for long periodsDave
