BEKO CG 964 COMPRESSOR RUNNING
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum BEKO CG 964 COMPRESSOR RUNNING
  • #81346
    derekhar
    Hello everyone, new here, but hope that someone may be able to help.
    I have a Beko CG 964 fridge freezer, which has been in store for about two weeks. I have plugged it in, and although the fridge and freezer are working fine, the compressor runs continually despite what setting i put the thermostat to. is this normal on this self defrost model….. it was previously used in a utility room, where i could not hear it, so not sure how long t has done this.
    Thank you in anticipation.
    #416315
    Seamy
    Re: BEKO CG 964 COMPRESSOR RUNNING
    Are you sure its the compressor running all the time, maybe its the circulating fan you hear
    #416316
    Don’t both compressor and circulating fan work together and turn off together?
    #416317
    Frozen2
    Welcome to the club.
    I suspect your fridge, like mine, has run low on gas.
    I ran mine for months on a timer to avoid the fridge section freezing solid.
    Meanwhile I tried all sorts. New board etc.
    Eventually I gave in and bought another.
    They last 2 years. Just after the warranty runs out.
    #416318
    derekhar
    Thanks for your suggestions, since posting, I have turned the thermostat down to min, and after approx 2 hours it switched off. i turned the stst up again and the compressor runs, but only seems to switch off when on min. The freezer temp is -17.5, and the fridge is 6.1.
    See how we go!
