Beko condenser dryer leaking
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Beko condenser dryer leaking
  • #86568
    Perox123
    Hi All,
    I have a Beko condenser dryer, model number DCU7230W. I noticed the other day that there was a little bit of water under the dryer – I thought nothing of it at first, cleaned it up and decided to see what happens. This morning I saw a fairly large amount of water under it – it hasn’t been used for a couple of days, we pulled it out to check it wasn’t the washing machine next to it, and the back of the machine (the black foam) was pretty soaked at the bottom, so the water must’ve been coming from here.
    The water is emptied regularly, so we’re not sure where this water might be coming from? I expect we’ll need to get an engineer out to look at it/fix it, but thought I would ask advice here first!
    Many thanks in advance,
    Perox123
    #432185
    Seamy
    Re: Beko condenser dryer leaking
    Likely a hose from duct blocked. Best get engineer to look at it, is condenser cleaned regularly?
