Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Beko condenser tumble dryer not pumping water from reservoir to water tank.
- This topic has 5 replies, 3 voices, and was last updated 6 years, 9 months ago by
Kimcole.
June 16, 2019 at 9:03 pm #96014
Kimcole
ParticipantHi
I have a beko DCX83100B . The Empty water light keeps flashing, despite the water drawer being empty. So I looked at the condenser pump unit and it was full of water, lint and fluff, so I took it out and removed all lint etc. Put it all back together, the dryer starts working again, for about 40 mins before the empty water light comes back on again, despite water drawer being empty.
So I look at the resevoire and it is full again, the water isn’t being pumped from the resevoire/collection tray at the bottom of the machine to the water drawer/tank at the top of the machine. So I think the condenser pump must be broken, I order a new one and replace it….but no joy, water is still not being pumped to the tank. Any ideas on why the water isn’t pumping up to the water tank?? The machine works just fine if I empty the resevoire manually, until the flotation device hits the switch saying it’s full and turns the machine off.
Any help/advice appreciate Thank you.June 16, 2019 at 10:35 pm #462068electrofix
Moderatorwell there is not much it can be
pump
blockage
overflow switchDave
June 20, 2019 at 6:45 am #462069Kimcole
ParticipantHi
I’ve replaced the pump, no joy. So I replaced the microswitch, still no joy. I’ve flushed the pipes and there’s no blockage.
I’m out of ideas as to what the problem could be ???June 20, 2019 at 8:40 am #462070electrofix
Moderatorwould not have gone as far as changing components without testing first but you can now say you have eliminated everything except the board or the long shot of a broken wire from the board to the pump
January 27, 2022 at 7:06 am #462071Mrs JD
ParticipantHello, did you manage to fix the problem on your Beko dryer. I’m having the same issue with my Beko DCU 7230 B.
The pump has been replaced and my husband has checked the float switch. He thinks most of the pipes are clear but is going to take the top pipe off at the drawer container end and check that too.
Thanks in advance for any help.
JDJanuary 27, 2022 at 9:43 am #462072electrofix
Moderatoryou need to check all pipes and waterways are clear before you jump to conclusions
Dave -
