Re: Beko Condensor Dryer DRCS68W Cutting Out
Just like to add ,check the float switch at the back near pump .Make sure it is seated correctly and is operating as it should.Had one that did the same thing and found that float switch was not seated right (dryer was un even on floor so not sure if it was disturbed with movement ,reseated and operated switch a few times with my finger on the metal part of the switch and been working perfectly ever since).
