Re: Beko Condensor Dryer/Hand Shredder DRCS65w H
I think there was a screw somewhere holding either pump or cover?
Finally sorted this one out, I think we will see a far few of these as the pump looks very prone to rust and seize up.
The whole job can be easily done through the inspection plate hole. The one thing to look for is a small philips screw on the top cover of the pump housing. Once that is out the cover unclips easily and the pump just lifts out.
Beware of sharp edges around inspection hole cover!
